ONTAP commands
system node usb-ports show
Display the state of the external USB ports
The system node usb-ports show command displays the status of the external USB ports on each node.
[-fields <fieldname>,…​]
| [-instance ] (privilege: advanced) }
[-node {<nodename>|local}] - Node That Owns the External USB Ports (privilege: advanced)
If this parameter is specified, the command displays information about the status of the external USB ports on the specified node.
[-is-disabled {true|false}] - Current State of the External USB Ports (privilege: advanced)
This parameter specifies the current state of the external USB ports.
[-is-disabled-next-boot {true|false}] - State of the External USB Ports on the Next Boot (privilege: advanced)
This parameter specifies the state of the external USB ports after the next boot.
[-is-feature-supported {true|false}] - External USB Ports Supported? (privilege: advanced)
This parameter specifies whether or not the node even supports external USB ports.
[-connected-ports {true|false}] - Connected USB Devices (privilege: advanced)
This parameter specifies whether or not the USB ports have a device connected to them.
The following example displays information about the state of the external USB ports:
cluster1::> system node usb-ports show
Node                     Disabled?           Disabled on Next Boot?  Supported? Devices Connected to Ports
node1                    false               true                    true       false
