The requested article is not available. Either it doesn't apply to this version of the product or the relevant information is organized differently in this version of the docs. You can search, browse, or go back to the other version.
system bridge config-dump delete
PDF of this doc site
Creating your file...
Your file is ready
Delete a dumpconfiguration file
The system bridge config-dump delete
command deletes dumpconfiguration files previously retrieved with the system bridge config-dump collect command.
-node {<nodename>|local}
- Node (privilege: advanced)-
Use this parameter to delete a dumpconfiguration file stored on the specified node.
-file <text>
- Config File (privilege: advanced)-
Use this parameter to delete the dumpconfiguration file with the specified file name.
The following example deletes dsbridge_config.FB7500N100001.2017-04-28_14_49_30.txt from node1:
cluster1::*> system bridge config-dump delete -node node1 -file dsbridge_config.FB7500N100001.2017-04-28_14_49_30.txt cluster1::*>
