      system bridge config-dump delete
Delete a dumpconfiguration file
The system bridge config-dump delete command deletes dumpconfiguration files previously retrieved with the system bridge config-dump collect command.
- -node {<nodename>|local}- Node (privilege: advanced)
Use this parameter to delete a dumpconfiguration file stored on the specified node.
- -file <text>- Config File (privilege: advanced)
Use this parameter to delete the dumpconfiguration file with the specified file name.
The following example deletes dsbridge_config.FB7500N100001.2017-04-28_14_49_30.txt from node1:
cluster1::*> system bridge config-dump delete -node node1 -file dsbridge_config.FB7500N100001.2017-04-28_14_49_30.txt cluster1::*>
 PDFs
PDFs
