vserver nvme subsystem map show
Display namespace maps within the subsystem
The vserver nvme subsystem map show command displays information about NVMe subsystem maps.
{ [-fields <fieldname>,…​]
| [-instance ] }
[-vserver <Vserver Name>] - Vserver Name
Use this parameter to display the NVMe subsystem maps that match the Vserver that you specify.
[-subsystem <text>] - Subsystem
Use this parameter to display the NVMe subsystem maps that match the subsystem that you specify.
[-nsid <Hex 32bit Integer>] - NSID
Use this parameter to display the NVMe subsystem maps that match the NVMe namespace NSID that you specify.
[-path <path>] - Namespace Path
Use this parameter to display the NVMe subsystem maps that match the NVMe namespace path that you specify.
[-anagrpid <Hex 32bit Integer>] - ANA Group ID (privilege: advanced)
Use this parameter to display the NVMe namespaces that match the Asymmetric Namespace Access (ANA) group identifier that you specify.
[-namespace-uuid <UUID>] - Namespace UUID
Use this parameter to display the NVMe ubsystem maps that match the NVMe namespace UUID that you specify.
cluster-1::*> vserver nvme subsystem map show -vserver vs_1
Vserver       Subsystem      NSID Namespace Path
vs_1          sub_1
                        00000001h /vol/nsvol1/ns1
                        00000002h /vol/nsvol1/ns2
2 entries were displayed.
