vserver nvme subsystem map show
PDF of this doc site
Creating your file...
Display namespace maps within the subsystem
The vserver nvme subsystem map show
command displays information about NVMe subsystem maps.
[-fields <fieldname>,…]
If you specify the
-fields <fieldname>, …
parameter, the command output also includes the specified field or fields. You can use '-fields ?' to display the fields to specify. - |
[-instance ]
If you specify the
-instance
parameter, the command displays detailed information about all fields. [-vserver <Vserver Name>]
- Vserver Name-
Use this parameter to display the NVMe subsystem maps that match the Vserver that you specify.
[-subsystem <text>]
- Subsystem-
Use this parameter to display the NVMe subsystem maps that match the subsystem that you specify.
[-nsid <Hex 32bit Integer>]
- NSID-
Use this parameter to display the NVMe subsystem maps that match the NVMe namespace NSID that you specify.
[-path <path>]
- Namespace Path-
Use this parameter to display the NVMe subsystem maps that match the NVMe namespace path that you specify.
[-anagrpid <Hex 32bit Integer>]
- ANA Group ID (privilege: advanced)-
Use this parameter to display the NVMe namespaces that match the Asymmetric Namespace Access (ANA) group identifier that you specify.
[-namespace-uuid <UUID>]
- Namespace UUID-
Use this parameter to display the NVMe ubsystem maps that match the NVMe namespace UUID that you specify.
cluster-1::*> vserver nvme subsystem map show -vserver vs_1 Vserver Subsystem NSID Namespace Path ------------- --------- --------- ------------------------------------------ vs_1 sub_1 00000001h /vol/nsvol1/ns1 00000002h /vol/nsvol1/ns2 2 entries were displayed.
