vserver nvme subsystem map show
Display namespace maps within the subsystem
The vserver nvme subsystem map show command displays information about NVMe subsystem maps.
- { [-fields <fieldname>,…]
If you specify the -fields <fieldname>, …parameter, the command output also includes the specified field or fields. You can use '-fields ?' to display the fields to specify.
- | [-instance ]}
If you specify the -instanceparameter, the command displays detailed information about all fields.
- [-vserver <Vserver Name>]- Vserver Name
Use this parameter to display the NVMe subsystem maps that match the Vserver that you specify.
- [-subsystem <text>]- Subsystem
Use this parameter to display the NVMe subsystem maps that match the subsystem that you specify.
- [-nsid <Hex 32bit Integer>]- NSID
Use this parameter to display the NVMe subsystem maps that match the NVMe namespace NSID that you specify.
- [-path <path>]- Namespace Path
Use this parameter to display the NVMe subsystem maps that match the NVMe namespace path that you specify.
- [-anagrpid <Hex 32bit Integer>]- ANA Group ID (privilege: advanced)
Use this parameter to display the NVMe namespaces that match the Asymmetric Namespace Access (ANA) group identifier that you specify.
- [-namespace-uuid <UUID>]- Namespace UUID
Use this parameter to display the NVMe ubsystem maps that match the NVMe namespace UUID that you specify.
cluster-1::*> vserver nvme subsystem map show -vserver vs_1
Vserver       Subsystem      NSID Namespace Path
vs_1          sub_1
                        00000001h /vol/nsvol1/ns1
                        00000002h /vol/nsvol1/ns2
2 entries were displayed.
 PDFs
PDFs
