The requested article is not available. Either it doesn't apply to this version of the product or the relevant information is organized differently in this version of the docs. You can search, browse, or go back to the other version.
event filter prepare-for-revert
PDF of this doc site
Creating your file...
Your file is ready
Deletes unsupported filter or updates unsupported parameter-criteria (parameter-criteria values other than =)
The event filter prepare-for-revert
command can be used to remove event filters or update event filter rules that are not supported when the cluster reverts to the previous release. Event filters with rules having a parameter-criteria
value other than *=*
are not supported.
-delete-unsupported-filters {true|false}
- Clear Unsupported Filters (privilege: advanced) -
Use this parameter to delete the event filters that are not supported in the previous release.
-update-unsupported-filter-param-criteria {true|false}
- Update Unsupported Filter Parameter Criteria (privilege: advanced) } -
Use this parameter to update the event filter rules that are not supported in the previous release to
The following shows examples of "event filter prepare-for-revert":
cluster1::> event filter show Filter Rule Rule SNMP Trap Name Posn Type Message Name Severity Type Parameters ----------- ---- -------- ------------- ----------- --------- ---------- default-trap-events 1 include * EMERGENCY, ALERT * *=* 2 include * * Standard, Built-in *=* 3 exclude * * * *=* important-events 1 include * EMERGENCY, ALERT * *=* 2 include callhome.* ERROR * *=* 3 exclude * * * *=* no-info-debug-events 1 include * EMERGENCY, ALERT, ERROR, NOTICE * *=* 2 exclude * * * *=* wafl-filter 1 include wafl.* EMERGENCY * vol=xyz 2 exclude * * * *=* 10 entries were displayed. cluster1::*> event filter prepare-for-revert -delete-unsupported-filters true cluster1::> event filter show Filter Rule Rule SNMP Trap Name Posn Type Message Name Severity Type Parameters ----------- ---- -------- ------------- ----------- --------- ---------- default-trap-events 1 include * EMERGENCY, ALERT * *=* 2 include * * Standard, Built-in *=* 3 exclude * * * *=* important-events 1 include * EMERGENCY, ALERT * *=* 2 include callhome.* ERROR * *=* 3 exclude * * * *=* no-info-debug-events 1 include * EMERGENCY, ALERT, ERROR, NOTICE * *=* 2 exclude * * * *=* 8 entries were displayed.
