snapmirror mediator show
PDF of this doc site
Creating your file...
Show mediator information
The snapmirror mediator show
command shows the status of the ONTAP Mediator configuration.
[-fields <fieldname>,…]
If you specify the
-fields <fieldname>, …
parameter, the command output also includes the specified field or fields. You can use '-fields ?' to display the fields to specify. - |
[-instance ]
If you specify the
-instance
parameter, the command displays detailed information about all fields. [-mediator-address <IP Address>]
- Mediator IP Address-
Ip address of the mediator.
[-peer-cluster <text>]
- Peer Cluster Name-
Peer cluster name.
[-connection-status {connected|unreachable|suspended|unusable|misconfigured|removing|not-configured|unknown|adding}]
- Connection Status-
Connection status of the cluster with the mediator.
[-quorum-status {unknown|true|false}]
- Mediator Quorum Status-
Shows whether the SnapMirror Consistency Group relationships are synchronized with mediator.
[-health-fetch-timeout <integer>]
- Peer Health Fetch Timeout-
Timeout value (in seconds) for peer-cluster health fetch via mediator.
[-connection-timeout <integer>]
- Connection Timeout-
Timeout value (in seconds) for mediator connection.
The following example shows the list of mediator configurations.
clusA::*> snapmirror mediator show Mediator Address Peer Cluster Connection Status Quorum Status ---------------- ---------------- ----------------- ------------- 10.140.102.227 clusB unreachable true clusA::*> snapmirror mediator show -instance Mediator Uuid: 416fbdee-c982-11e9-9034-005056a7124c Mediator IP Address: 10.140.102.227 Peer Cluster: clusB Peer Cluster Uuid: 771d9b13-c973-11e9-928e-005056a7a882 Connection Status: unreachable Quorum Status: true Health Fetch Timeout: 5 Connection Timeout: 5
