Command reference
snapmirror mediator show
Show mediator information
The snapmirror mediator show command shows the status of the ONTAP Mediator configuration.
{ [-fields <fieldname>,…​]
| [-instance ] }
[-mediator-address <IP Address>] - Mediator IP Address
Ip address of the mediator.
[-peer-cluster <text>] - Peer Cluster Name
Peer cluster name.
[-connection-status {connected|unreachable|suspended|unusable|misconfigured|removing|not-configured|unknown|adding|down-high-latency}] - Connection Status
Connection status of the cluster with the mediator.
[-quorum-status {unknown|true|false}] - Mediator Quorum Status
Shows whether the SnapMirror Consistency Group relationships are synchronized with mediator.
[-health-fetch-timeout <integer>] - Peer Health Fetch Timeout
Timeout value (in seconds) for peer-cluster health fetch via mediator.
[-connection-timeout <integer>] - Connection Timeout
Timeout value (in seconds) for mediator connection.
[-type {on-prem|cloud}] - Mediator Type
Specifies the type of the mediator. The value on-prem represents ONTAP Mediator. The value cloud represents ONTAP cloud mediator.
[-critical-api-timeout <integer>] - Critical API Timeout
Timeout value (in seconds) for the critical APIs invoked in IO-impacting workflows of a SnapMirror active sync relationship, such as planned failover, automatic unplanned failover and OutOfSync handling. The default value is 5 sec for ONTAP Mediator and 7 sec for ONTAP cloud mediator.
[-non-critical-api-timeout <integer>] - Non-critical API Timeout
Timeout value (in seconds) for the non-critical APIs invoked in non-IO-impacting workflows, such as mediator configuration, mediator removal, creation and deletion of a SnapMirror active sync relationship. The default value is 5 sec for ONTAP Mediator and 34 sec for ONTAP cloud mediator.
[-longpoll-overhead-timeout <integer>] - Long-poll Overhead Timeout
Timeout value (in seconds) for long-poll operation to account for processing delays.
[-use-http-proxy {true|false}] - Use HTTP Proxy on Cluster
Whether this cluster uses an http proxy server while making REST API calls to mediator or not.
[-ping-network-rtt <integer>] - Network RTT Ms
Network RTT (in milliseconds) between ONTAP and the BlueXP cloud server as observed during the ping-test.
[-latency-status-list <text>,…​] - Node-wise API Latency Status List
List of API call latency status being reported by the nodes of the cluster. This option is only supported for ONTAP cloud mediator.
The following example shows an ONTAP Mediator configuration.
clusA::> snapmirror mediator show
        Mediator Address Peer Cluster     Connection Status Quorum Status Type
        10.140.102.227   clusB            connected         true          on-prem
clusA::> snapmirror mediator show -instance
Mediator Uuid: 416fbdee-c982-11e9-9034-005056a7124c
                  Mediator IP Address: 10.140.102.227
                         Peer Cluster: clusB
                    Peer Cluster Uuid: 771d9b13-c973-11e9-928e-005056a7a882
                    Connection Status: connected
                        Quorum Status: true
                                 Type: on-prem
                 Health Fetch Timeout: 5
                   Connection Timeout: 5
                Mediator Read Timeout: 5
               Mediator Write Timeout: 5
           Long-poll Overhead Timeout: 2
                Use HTTP Proxy Server: false
        Strict Certificate Validation: false
               BlueXP Server Ping URL: -
                Ping Network RTT (ms): -
         Node-wise API Latency Status: -
The following example shows an ONTAP cloud mediator configuration.
        0.0.0.0          clusB            connected         true          cloud
Mediator Uuid: e314083d-053f-11f0-badf-005056ae1773
                  Mediator IP Address: 0.0.0.0
                         Peer Cluster: clusB
                    Peer Cluster Uuid: 9a21429f-0487-11f0-ac98-005056ae112c
                    Connection Status: true
                        Quorum Status: true
                                 Type: cloud
                Mediator Read Timeout: 6
               Mediator Write Timeout: 6
                Use HTTP Proxy Server: true
        Strict Certificate Validation: true
               BlueXP Server Ping URL: api.bluexp.netapp.com
                Ping Network RTT (ms): 100
         Node-wise API Latency Status: NodeA: normal, NodeB: normal
