snapmirror mediator show
Show mediator information
The snapmirror mediator show command shows the status of the ONTAP Mediator configuration.
- { [-fields <fieldname>,…]
If you specify the -fields <fieldname>, …parameter, the command output also includes the specified field or fields. You can use '-fields ?' to display the fields to specify.
- | [-instance ]}
If you specify the -instanceparameter, the command displays detailed information about all fields.
- [-mediator-address <IP Address>]- Mediator IP Address
Ip address of the mediator.
- [-peer-cluster <text>]- Peer Cluster Name
Peer cluster name.
- [-connection-status {connected|unreachable|suspended|unusable|misconfigured|removing|not-configured|unknown|adding}]- Connection Status
Connection status of the cluster with the mediator.
- [-quorum-status {unknown|true|false}]- Mediator Quorum Status
Shows whether the SnapMirror Consistency Group relationships are synchronized with mediator.
- [-health-fetch-timeout <integer>]- Peer Health Fetch Timeout
Timeout value (in seconds) for peer-cluster health fetch via mediator.
- [-connection-timeout <integer>]- Connection Timeout
Timeout value (in seconds) for mediator connection.
The following example shows the list of mediator configurations.
clusA::*> snapmirror mediator show
      Mediator Address Peer Cluster     Connection Status Quorum Status
      10.140.102.227   clusB        unreachable       true
clusA::*> snapmirror mediator show -instance
Mediator Uuid: 416fbdee-c982-11e9-9034-005056a7124c
      Mediator IP Address: 10.140.102.227
      Peer Cluster: clusB
      Peer Cluster Uuid: 771d9b13-c973-11e9-928e-005056a7a882
      Connection Status: unreachable
      Quorum Status: true
      Health Fetch Timeout: 5
      Connection Timeout: 5
 PDFs
PDFs
