The requested article is not available. Either it doesn't apply to this version of the product or the relevant information is organized differently in this version of the docs. You can search, browse, or go back to the other version.
volume analytics on
PDF of this doc site
Creating your file...
Your file is ready
Enable collection of file system analytics for a volume
The volume analytics on
command enables file system usage analytics on a volume.
-vserver <vserver name>
- Vserver Name-
This specifies the Vserver in which the volume is located.
-volume <volume name>
- Volume Name-
This specifies the name of the volume on which file system usage analytics is being enabled.
[-foreground <true>]
- Run Operation in the Foreground-
If true, the command doesn't complete until the
analytics-state
of the volume ison
. If false, the command returns immediately, and theanalytics-state
andscan-progress
can be tracked using the volume analytics show command.
The following example enables file system usage analytics on a flexible volume named "flexvol" in Vserver "vs1":
cluster::*> volume analytics on -vserver vs1 -volume flexvol
