ONTAP commands
volume analytics on
Enable collection of file system analytics for a volume
The volume analytics on command enables file system usage analytics on a volume.
-vserver <vserver name> - Vserver Name
This specifies the Vserver in which the volume is located.
-volume <volume name> - Volume Name
This specifies the name of the volume on which file system usage analytics is being enabled.
[-foreground <true>] - Run Operation in the Foreground
If true, the command doesn't complete until the analytics-state of the volume is on . If false, the command returns immediately, and the analytics-state and scan-progress can be tracked using the volume analytics show command.
The following example enables file system usage analytics on a flexible volume named "flexvol" in Vserver "vs1":
cluster::*> volume analytics on -vserver vs1 -volume flexvol
