volume analytics on
- PDF of this doc site
Creating your file...
Your file is ready
Enable collection of file system analytics for a volume
The volume analytics on
command enables file system usage analytics on a volume.
-vserver <vserver name>
- Vserver Name-
This specifies the Vserver in which the volume is located.
-volume <volume name>
- Volume Name-
This specifies the name of the volume on which file system usage analytics is being enabled.
[-foreground <true>]
- Run Operation in the Foreground-
If true, the command doesn't complete until the
analytics-state
of the volume ison
. If false, the command returns immediately, and theanalytics-state
andscan-progress
can be tracked using the volume analytics show command.
The following example enables file system usage analytics on a flexible volume named "flexvol" in Vserver "vs1":
cluster::*> volume analytics on -vserver vs1 -volume flexvol
