volume analytics show
PDF of this doc site
Creating your file...
Display file system analytics information
The volume analytics show
command displays the file system analytics information for a volume. By default, the command displays the following information:
Vserver name
Volume name
File system analytics state
[-fields <fieldname>,…]
If you specify the
-fields <fieldname>, …
parameter, the command output also includes the specified field or fields. You can use '-fields ?' to display the fields to specify. - |
[-instance ]
If you specify the
-instance
parameter, the command displays detailed information about all fields. [-vserver <vserver name>]
- Vserver Name-
If this parameter and the
-volume
parameter are specified, the command displays file system analytics information about the specified volume. If this parameter is specified by itself, the command displays information about volumes on the specified Vserver. [-volume <volume name>]
- Volume Name-
-vserver
parameter are specified, the command displays file system analytics information about the specified volume. If this parameter is specified by itself, the command displays information about all volumes matching the specified name. [-state <Analytics State>]
- State-
If this parameter is specified, the command displays information only about the volume or volumes that have the specified file system analytics state.
[-scan-progress <percent>]
- Scan Progress-
If this parameter is specified, the command displays information only about the volume or volumes that have the specified file system analytics progress percentage. This value will only be set if a file system analytics initialization scan is in progress.
[-tracked-dirs <integer>]
- Tracked Directories-
If this parameter is specified, the command displays information only about the volume or volumes that have the specified number of tracked directories.
[-tracked-files <integer>]
- Tracked Files-
If this parameter is specified, the command displays information only about the volume or volumes that have the specified number of tracked files.
[-tracked-items <integer>]
- Tracked Items-
If this parameter is specified, the command displays information only about the volume or volumes that have the specified number of tracked items. An item is either a file or a directory.
[-top-level-dirs <integer>]
- Top Level Directories-
If this parameter is specified, the command displays information only about the volume or volumes that have the specified number of top level directories.
[-average-files-per-dir <integer>]
- Average Files Per Directory-
If this parameter is specified, the command displays information only about the volume or volumes that have the specified average number of files per directory.
The following example displays the file system analytics information on a flexible volume named "flexvol" in Vserver "vs1":
cluster::*> volume analytics show -vserver vs1 -volume flexvol Vserver Name: vs1 Volume Name: flexvol State: on Scan Progress: -
