ONTAP commands
volume analytics show
Display file system analytics information
The volume analytics show command displays the file system analytics information for a volume. By default, the command displays the following information:
  • Vserver name
  • Volume name
  • File system analytics state
{ [-fields <fieldname>,…​]
| [-instance ] }
[-vserver <vserver name>] - Vserver Name
If this parameter and the -volume parameter are specified, the command displays file system analytics information about the specified volume. If this parameter is specified by itself, the command displays information about volumes on the specified Vserver.
[-volume <volume name>] - Volume Name
If this parameter and the -vserver parameter are specified, the command displays file system analytics information about the specified volume. If this parameter is specified by itself, the command displays information about all volumes matching the specified name.
[-state <Analytics State>] - State
If this parameter is specified, the command displays information only about the volume or volumes that have the specified file system analytics state.
[-scan-progress <percent>] - Scan Progress
If this parameter is specified, the command displays information only about the volume or volumes that have the specified file system analytics progress percentage. This value will only be set if a file system analytics initialization scan is in progress.
[-tracked-dirs <integer>] - Tracked Directories
If this parameter is specified, the command displays information only about the volume or volumes that have the specified number of tracked directories.
[-tracked-files <integer>] - Tracked Files
If this parameter is specified, the command displays information only about the volume or volumes that have the specified number of tracked files.
[-tracked-items <integer>] - Tracked Items
If this parameter is specified, the command displays information only about the volume or volumes that have the specified number of tracked items. An item is either a file or a directory.
[-top-level-dirs <integer>] - Top Level Directories
If this parameter is specified, the command displays information only about the volume or volumes that have the specified number of top level directories.
[-average-files-per-dir <integer>] - Average Files Per Directory
If this parameter is specified, the command displays information only about the volume or volumes that have the specified average number of files per directory.
The following example displays the file system analytics information on a flexible volume named "flexvol" in Vserver "vs1":
cluster::*> volume analytics show -vserver vs1 -volume flexvol
Vserver Name: vs1
  Volume Name: flexvol
        State: on
Scan Progress: -
