volume analytics show
Display file system analytics information
The volume analytics show command displays the file system analytics information for a volume. By default, the command displays the following information:
Vserver name
Volume name
File system analytics state
[-fields <fieldname>,…] -
If you specify the
[-instance ]} -
If you specify the
-instanceparameter, the command displays detailed information about all fields. [-vserver <vserver name>]- Vserver Name-
If this parameter and the
-volumeparameter are specified, the command displays file system analytics information about the specified volume. If this parameter is specified by itself, the command displays information about volumes on the specified Vserver. [-volume <volume name>]- Volume Name-
-vserverparameter are specified, the command displays file system analytics information about the specified volume. If this parameter is specified by itself, the command displays information about all volumes matching the specified name. [-state <Analytics State>]- State-
If this parameter is specified, the command displays information only about the volume or volumes that have the specified file system analytics state.
 [-scan-progress <percent>]- Scan Progress-
If this parameter is specified, the command displays information only about the volume or volumes that have the specified file system analytics progress percentage. This value will only be set if a file system analytics initialization scan is in progress.
 [-tracked-dirs <integer>]- Tracked Directories-
If this parameter is specified, the command displays information only about the volume or volumes that have the specified number of tracked directories.
 [-tracked-files <integer>]- Tracked Files-
If this parameter is specified, the command displays information only about the volume or volumes that have the specified number of tracked files.
 [-tracked-items <integer>]- Tracked Items-
If this parameter is specified, the command displays information only about the volume or volumes that have the specified number of tracked items. An item is either a file or a directory.
 [-top-level-dirs <integer>]- Top Level Directories-
If this parameter is specified, the command displays information only about the volume or volumes that have the specified number of top level directories.
 [-average-files-per-dir <integer>]- Average Files Per Directory-
If this parameter is specified, the command displays information only about the volume or volumes that have the specified average number of files per directory.
 [-files-scanned <integer>]- Number of Files Scanned-
If this parameter is specified, the command displays information only about the volume or volumes that have the specified number of files scanned. This value will only be set if a file system analytics initialization scan is in progress.
 [-total-files <integer>]- Total Number of Files-
If this parameter is specified, the command displays information only about the volume or volumes that have the specified total number of files. This value will only be set if a file system analytics initialization scan is in progress.
The following example displays the file system analytics information on a flexible volume named "flexvol" in Vserver "vs1":
cluster::*> volume analytics show -vserver vs1 -volume flexvol
Vserver Name: vs1
  Volume Name: flexvol
        State: on
Scan Progress: -
