ONTAP 9.13.1 commands
system node hardware tape drive show
Displays information about tape drives
This command displays the following information about tape drives:
  • Node to which the tape drive is attached
  • Device ID of the tape drive
  • Description of the tape drive
  • NDMP path of the tape drive
{ [-fields <fieldname>,…​]
| [-instance ] }
[-node {<nodename>|local}] - Node
Displays detailed information about tape drives on the specified node.
[-device-id <text>] - Device ID
Selects information about the tape drive that has the specified device ID.
[-description <text>] - Description
Selects information about the tape drive or drives that have the specified description.
[-wwn <text>] - World Wide Name
Selects information about the tape drive that has the specified worldwide name.
[-serial-number <text>] - Serial Number
Selects information about the tape drive that has the specified serial number.
[-ndmp-path <text>,…​] - NDMP Path
Selects information about the tape drive or drives that have the specified NDMP path.
The following example displays information about all tape drives in the cluster:
cluster1::> system node hardware tape drive show
Node   Device Id Drive Description    NDMP Path
cluster1
       brocade-247-198:3.126L1        nrst0l nrst0m nrst0h nrst0a
                 IBM LTO 4 ULTRIUM    rst0l rst0m rst0h rst0a
                                      urst0l urst0m urst0h urst0a
       brocade-247-198:3.126L2        nrst1l nrst1m nrst1h nrst1a
                 IBM LTO 4 ULTRIUM    rst1l rst1m rst1h rst1a
                                      urst1l urst1m urst1h urst1a
       brocade-247-198:3.126L3        nrst2l nrst2m nrst2h nrst2a
                 IBM LTO 4 ULTRIUM    rst2l rst2m rst2h rst2a
                                      urst2l urst2m urst2h urst2a
       brocade-247-198:3.126L4        nrst3l nrst3m nrst3h nrst3a
                 IBM LTO 4 ULTRIUM    rst3l rst3m rst3h rst3a
                                      urst3l urst3m urst3h urst3a
       brocade-247-198:3.126L6        nrst5l nrst5m nrst5h nrst5a
                 SONY    SDX-400C     rst5l rst5m rst5h rst5a
                                      urst5l urst5m urst5h urst5a
     5 entries were displayed.
