network port ifgrp show
PDF of this doc site
Creating your file...
Display port interface groups
The network port ifgrp show
command displays information about port interface groups. By default, it displays information about all port interface groups on all nodes in the cluster.
[-fields <fieldname>,…]
If you specify the
-fields <fieldname>, …
parameter, the command output also includes the specified field or fields. You can use '-fields ?' to display the fields to specify. - |
[-instance ]
If you specify the
-instance
parameter, the command displays detailed information about all fields. [-node {<nodename>|local}]
- Node-
Selects the port interface groups that match this parameter value. Use this parameter with the
-ifgrp
parameter to select information about a specific port interface group. [-ifgrp <ifgrp name>]
- Interface Group Name-
-node
parameter, to select information about a specific port interface group. [-distr-func {mac|ip|sequential|port}]
- Distribution Function-
[-mode {multimode|multimode_lacp|singlemode}]
- Create Policy-
[-mac <MAC Address>]
- MAC Address-
[-activeports {full|partial|none}]
- Port Participation-
Selects the port interface groups that match this parameter value. The value "partial" indicates that some but not all of the port interface group's ports are active. the value "full" indicates that all of the port interface group's ports are active.
[-ports {<netport>|<ifgrp>}]
- Network Ports-
[-up-ports {<netport>|<ifgrp>}]
- Up Ports-
Selects the port interface groups that match this parameter value. Displays only the ports that are up.
[-down-ports {<netport>|<ifgrp>}]
- Down Ports-
Selects the port interface groups that match this parameter value. Displays only the ports that are down.
The following example displays information about all port interface groups.
cluster1::> network port ifgrp show Port Distribution Active Node ifgrp Function MAC Address Ports Ports ------ ------- ------------ -------------- ------- --------------- node0 a0a ip b8:f8:7a:20:00 partial e0c node1 a1a ip 07:26:60:02:00 full e0d
