ONTAP commands
network port ifgrp show
Display port interface groups
The network port ifgrp show command displays information about port interface groups. By default, it displays information about all port interface groups on all nodes in the cluster.
{ [-fields <fieldname>,…​]
| [-instance ] }
[-node {<nodename>|local}] - Node
Selects the port interface groups that match this parameter value. Use this parameter with the -ifgrp parameter to select information about a specific port interface group.
[-ifgrp <ifgrp name>] - Interface Group Name
Selects the port interface groups that match this parameter value. Use this parameter with the -node parameter, to select information about a specific port interface group.
[-distr-func {mac|ip|sequential|port}] - Distribution Function
[-mode {multimode|multimode_lacp|singlemode}] - Create Policy
[-mac <MAC Address>] - MAC Address
[-activeports {full|partial|none}] - Port Participation
Selects the port interface groups that match this parameter value. The value "partial" indicates that some but not all of the port interface group's ports are active. the value "full" indicates that all of the port interface group's ports are active.
[-ports {<netport>|<ifgrp>}] - Network Ports
[-up-ports {<netport>|<ifgrp>}] - Up Ports
Selects the port interface groups that match this parameter value. Displays only the ports that are up.
[-down-ports {<netport>|<ifgrp>}] - Down Ports
Selects the port interface groups that match this parameter value. Displays only the ports that are down.
The following example displays information about all port interface groups.
cluster1::> network port ifgrp show
        Port     Distribution                Active
Node    ifgrp    Function     MAC Address    Ports   Ports
node0
        a0a      ip           b8:f8:7a:20:00 partial e0c
node1
        a1a      ip           07:26:60:02:00 full    e0d
