snaplock compliance-clock ntp show
PDF of this doc site
Creating your file...
Your file is ready
Display SnapLock ComplianceClock synchronization setting
The ` snaplock compliance-clock ntp show ` command will display ComplianceClock synchronization setting. It will display the following information:
is-sync-enabled - Displays if the option to synchronize the ComplianceClock with system time has been enabled or not.
cluster1::> snaplock compliance-clock ntp show Enable clock sync to NTP system time: true
