ONTAP commands
snaplock compliance-clock ntp show
Display SnapLock ComplianceClock synchronization setting
The ` snaplock compliance-clock ntp show ` command will display ComplianceClock synchronization setting. It will display the following information:
  • is-sync-enabled - Displays if the option to synchronize the ComplianceClock with system time has been enabled or not.
cluster1::> snaplock compliance-clock ntp show
Enable clock sync to NTP system time: true
