system services ndmp node-scope-mode off
PDF of this doc site
Creating your file...
Your file is ready
(DEPRECATED)-Disable NDMP node-scope-mode
This node-scoped NDMP command is deprecated. Node-scoped NDMP functionality may be removed in a future release of Data ONTAP. Use the Vserver-aware "`vserver services ndmp` " command. |
This command puts NDMP server in Vserver-aware mode. The Vserver-aware commands are available under vserver services ndmp
The following example shows how to disable the node-scope-mode of NDMP server.
cluster1::> system services ndmp node-scope-mode off NDMP node-scope-mode is disabled.
