storage aggregate inode-upgrade resume
PDF of this doc site
Creating your file...
Your file is ready
Resume suspended inode upgrade
The storage aggregate inode-upgrade resume
command resumes a suspended inode upgrade process. The inode upgrade process might have been suspended earlier due to performance reasons.
-node {<nodename>|local}
- Node Name (privilege: advanced)-
If this parameter is specified, the command resumes the upgrade process of an aggregate that is located on the specified node.
-aggregate <aggregate name>
- Aggregate Name (privilege: advanced)-
This specifies the aggregate for which the inode upgrade process is to be resumed.
The following example resumes an aggregate upgrade process:
cluster1::> storage aggregate inode-upgrade resume -aggregate aggr1
