The requested article is not available. Either it doesn't apply to this version of the product or the relevant information is organized differently in this version of the docs. You can search, browse, or go back to the other version.
vserver cifs remove-netbios-aliases
- PDF of this doc site
Creating your file...
Your file is ready
Remove NetBIOS aliases
The `vserver cifs remove-netbios-aliases` command deletes NetBIOS aliases for the CIFS server.
-vserver <vserver name>
- Vserver-
This parameter specifies the name of the Vserver from which the list of NetBIOS aliases are deleted.
-netbios-aliases <NetBIOS>,…
- List of NetBIOS Aliases-
This parameter specifies one or more NetBIOS aliases to be deleted. To delete all the NetBIOS aliases of a Vserver use '-'.
The following example deletes NetBIOS aliases for the CIFS server CIFS_SERVER on Vserver vs_a.
cluster1::> cifs show -display-netbios-aliases Vserver: vs_a Server Name: CIFS_SERVER NetBIOS Aliases: ALIAS_1, ALIAS_2, ALIAS_3, ALIAS_4, ALIAS_5, ALIAS_6, ALIAS_7 cluster1::> cifs remove-netbios-aliases -netbios-aliases alias_1,alias_3,alias_5 cluster1::> cifs show -display-netbios-aliases Vserver: vs_a Server Name: CIFS_SERVER NetBIOS Aliases: ALIAS_2, ALIAS_4, ALIAS_6, ALIAS_7 cluster1::> cifs remove-netbios-aliases -netbios-aliases alias_7 cluster1::> cifs show -display-netbios-aliases Vserver: vs_a Server Name: CIFS_SERVER NetBIOS Aliases: ALIAS_2, ALIAS_4, ALIAS_6 cluster1::> cifs remove-netbios-aliases -netbios-aliases - cluster1::> cifs show -display-netbios-aliases Vserver: vs_a Server Name: CIFS_SERVER NetBIOS Aliases: -
