      vserver cifs remove-netbios-aliases
Remove NetBIOS aliases
The `vserver cifs remove-netbios-aliases` command deletes NetBIOS aliases for the CIFS server.
-vserver <vserver name>- Vserver-
This parameter specifies the name of the Vserver from which the list of NetBIOS aliases are deleted.
 -netbios-aliases <NetBIOS>,…- List of NetBIOS Aliases-
This parameter specifies one or more NetBIOS aliases to be deleted. To delete all the NetBIOS aliases of a Vserver use '-'.
The following example deletes NetBIOS aliases for the CIFS server CIFS_SERVER on Vserver vs_a.
cluster1::> cifs show -display-netbios-aliases
Vserver: vs_a
Server Name: CIFS_SERVER
  NetBIOS Aliases: ALIAS_1, ALIAS_2, ALIAS_3, ALIAS_4,
                   ALIAS_5, ALIAS_6, ALIAS_7
cluster1::> cifs remove-netbios-aliases -netbios-aliases alias_1,alias_3,alias_5
Vserver: vs_a
  NetBIOS Aliases: ALIAS_2, ALIAS_4, ALIAS_6, ALIAS_7
cluster1::> cifs remove-netbios-aliases -netbios-aliases alias_7
Vserver: vs_a
cluster1::> cifs remove-netbios-aliases -netbios-aliases -
Vserver: vs_a
  NetBIOS Aliases: -
