storage stackmon repair show
PDF of this doc site
Creating your file...
Display repairs that will be made to stackmon if \"storage stackmon repair run\" is executed
The storage stackmon repair show
command diagnoses stackmon reconciliation failures and displays the repairs that will be made if storage stackmon repair run is executed:
[-fields <fieldname>,…]
If you specify the
-fields <fieldname>, …
parameter, the command output also includes the specified field or fields. You can use '-fields ?' to display the fields to specify. - |
[-instance ]
If you specify the
-instance
parameter, the command displays detailed information about all fields. [-shelf-uid <integer>]
- Shelf UID (privilege: advanced)-
Displays the stackmon repairs for the specified shelf. Use storage shelf show -fields shelf-uuid to find the shelf-uid.
[-old-stack-id <integer>]
- Old Stack ID (privilege: advanced)-
Displays the stackmon repairs with the specified current stack-id.
[-new-stack-id <integer>]
- New Stack ID (privilege: advanced)-
Displays the stackmon repairs with the specified new stack-id.
[-skip-check-stackmon-state <true>]
- Skip Check for Stackmon State (privilege: advanced)-
This parameter allows the command to be executed when stackmon is still running.
The following example displays the stackmon repairs:
cluster 1::*> storage stackmon repair show Shelf Old Stack New Stack -------------------- --------- --------- 123370712932616784 1 1 292812051842665040 3 1 4342319975102154064 2 2 4558492757215937872 2 2 5350844816656434512 1 1 9274403680772754000 1 1 9346461274810681936 2 2 10786768730639108688 2 2 8 entries were displayed.
