vserver fcp initiator show
PDF of this doc site
Creating your file...
Display FCP initiators currently connected
This command displays information about FCP initiators that are currently logged in.
If you do not specify a Vserver, the command displays all initiators logged into all FCP Vservers within a cluster. If you specify a Vserver but not a logical interface, the command displays information about all initiators connected to all logical interfaces within the specified Vserver.
If an initiator belongs to an initiator group or has a World Wide Port Name (WWPN) alias, the command displays this information.
[-fields <fieldname>,…]
If you specify the
-fields <fieldname>, …
parameter, the command output also includes the specified field or fields. You can use '-fields ?' to display the fields to specify. - |
[-instance ]
If you specify the
-instance
parameter, the command displays detailed information about all fields. [-vserver <Vserver Name>]
- Vserver Name-
Use this parameter to display the FCP initiators logged into the Vserver that you specify.
[-lif <lif-name>]
- Logical Interface-
Use this parameter to display the FCP initiators that match the logical interfaces that you specify.
[-wwpn <FC WWN>]
- WWPN-
Use this parameter to display the FCP initiators that matches the World Wide Port Name (WWPN) that you specify.
[-wwnn <FC WWN>]
- WWNN-
Use this parameter to display the FCP initiator that matches the World Wide Node Name (WWNN) that you specify.
[-port-address <Hex Integer>]
- Port Addres-
Use this parameter to display FCP initiators that match the port address that you specify.
[-alias <text>,…]
- Initiator WWPN Alias-
Use this parameter to display the FCP initiator that matches the alias name that you specify.
[-igroup <text>,…]
- Igroup Name-
Use this parameter to display the FCP initiator that matches the initiator group that you specify.
[-data-protocol {fcp|fc-nvme}]
- Data Protocol-
Use this parameter to display the FCP initiator that matches the data protocol that you specify.
cluster1::> vserver fcp initiator show Logical Initiator Initiator Vserver Interface WWNN WWPN Igroup --------- ---------- -------------- ------------- ------------------------- vs1 vs1.fcp 2f:a2:00:a0:98:0b:56:13 2f:a2:00:a0:98:0b:56:15 igroup1
Displays information regarding all logged in FCP initiators.
