The requested article is not available. Either it doesn't apply to this version of the product or the relevant information is organized differently in this version of the docs. You can search, browse, or go back to the other version.
metrocluster check disable-periodic-check
PDF of this doc site
Creating your file...
Your file is ready
Disable Periodic Check
The metrocluster check disable-periodic-check
command disables the periodic checking of the MetroCluster configuration.
After this command is run, the MetroCluster Check job will be prevented from periodically checking the configuration for errors.
clusA::> metrocluster check disable-periodic-check
