metrocluster check disable-periodic-check
Disable Periodic Check
The metrocluster check disable-periodic-check
command disables the periodic checking of the MetroCluster configuration.
After this command is run, the MetroCluster Check job will be prevented from periodically checking the configuration for errors.
clusA::> metrocluster check disable-periodic-check
