ONTAP commands
storage aggregate object-store show-freeing-status
Show status of background object freeing work after aggregate delete
The storage aggregate object-store show-freeing-status command displays status information about the background work that frees an aggregate's objects from an object store after a storage aggregate delete .
{ [-fields <fieldname>,…​]
| [-instance ] }
[-bin-uuid <UUID>] - UUID of the Bin (privilege: advanced)
If this parameter is specified, the command displays information only about the aggregate attached to the specified bin UUID.
[-config-id <integer>] - Object Store Config ID (privilege: advanced)
If this parameter is specified, the command displays information only about the aggregate attached to the object- store with specified config ID.
[-object-store-name <text>] - Object Store Configuration Name (privilege: advanced)
If this parameter is specified, the command displays information only about object stores whose configuration name matches the specified names.
[-aggregate-name <aggregate name>] - Aggregate (privilege: advanced)
If this parameter is specified, the command displays information only about the specified aggregates that were deleted.
[-request-state {queued|running|cleaning-up|finishing}] - Request State (privilege: advanced)
If this parameter is specified, the command displays information only about the object stores that have the specified object freeing request state.
[-num-objects-freed <integer>] - Num Objects Freed (privilege: advanced)
If this parameter is specified, the command displays information only about the object stores that have the specified number of objects that have been freed.
[-last-error <text>] - The Last Error Encountered (privilege: advanced)
If this parameter is specified, the command displays information only about the object stores that have the specified last error encountered.
