storage aggregate object-store show-freeing-status
Show status of background object freeing work after aggregate delete
The storage aggregate object-store show-freeing-status command displays status information about the background work that frees an aggregate's objects from an object store after a storage aggregate delete .
- [-fields <fieldname>,…]
If you specify the -fields <fieldname>, …parameter, the command output also includes the specified field or fields. You can use '-fields ?' to display the fields to specify.
- | [-instance ](privilege: advanced) }
If you specify the -instanceparameter, the command displays detailed information about all fields.
- [-bin-uuid <UUID>]- UUID of the Bin (privilege: advanced)
If this parameter is specified, the command displays information only about the aggregate attached to the specified bin UUID.
- [-config-id <integer>]- Object Store Config ID (privilege: advanced)
If this parameter is specified, the command displays information only about the aggregate attached to the object- store with specified config ID.
- [-object-store-name <text>]- Object Store Configuration Name (privilege: advanced)
If this parameter is specified, the command displays information only about object stores whose configuration name matches the specified names.
- [-aggregate-name <aggregate name>]- Aggregate (privilege: advanced)
If this parameter is specified, the command displays information only about the specified aggregates that were deleted.
- [-request-state {queued|running|cleaning-up|finishing}]- Request State (privilege: advanced)
If this parameter is specified, the command displays information only about the object stores that have the specified object freeing request state.
- [-num-objects-freed <integer>]- Num Objects Freed (privilege: advanced)
If this parameter is specified, the command displays information only about the object stores that have the specified number of objects that have been freed.
- [-last-error <text>]- The Last Error Encountered (privilege: advanced)
If this parameter is specified, the command displays information only about the object stores that have the specified last error encountered.
 PDFs
PDFs
