storage aggregate object-store show-freeing-status
Show status of background object freeing work after aggregate delete
The storage aggregate object-store show-freeing-status
command displays status information about the background work that frees an aggregate's objects from an object store after a storage aggregate delete .
[-fields <fieldname>,…]
If you specify the
-fields <fieldname>, …
parameter, the command output also includes the specified field or fields. You can use '-fields ?' to display the fields to specify. - |
[-instance ]
If you specify the
-instance
parameter, the command displays detailed information about all fields. [-bin-uuid <UUID>]
- UUID of the Bin (privilege: advanced)-
If this parameter is specified, the command displays information only about the aggregate attached to the specified bin UUID.
[-config-id <integer>]
- Object Store Config ID (privilege: advanced)-
If this parameter is specified, the command displays information only about the aggregate attached to the object- store with specified config ID.
[-object-store-name <text>]
- Object Store Configuration Name (privilege: advanced)-
If this parameter is specified, the command displays information only about object stores whose configuration name matches the specified names.
[-aggregate-name <aggregate name>]
- Aggregate (privilege: advanced)-
If this parameter is specified, the command displays information only about the specified aggregates that were deleted.
[-request-state {queued|running|cleaning-up|finishing}]
- Request State (privilege: advanced)-
If this parameter is specified, the command displays information only about the object stores that have the specified object freeing request state.
[-num-objects-freed <integer>]
- Num Objects Freed (privilege: advanced)-
If this parameter is specified, the command displays information only about the object stores that have the specified number of objects that have been freed.
[-last-error <text>]
- The Last Error Encountered (privilege: advanced)-
If this parameter is specified, the command displays information only about the object stores that have the specified last error encountered.
