The requested article is not available. Either it doesn't apply to this version of the product or the relevant information is organized differently in this version of the docs. You can search, browse, or go back to the other version.
statistics preset show
PDF of this doc site
Creating your file...
Your file is ready
Display information about Performance Presets
Displays information about performance preset configurations.
[-fields <fieldname>,…]
Selects which performance preset attributes to display.
[-instance ]
Shows details of all attributes of performance preset configuration.
[-preset <text>]
- Preset Name (privilege: advanced)-
Selects the performance presets that match the specified preset name.
[-comment <text>]
- Preset Description (privilege: advanced)-
Selects the performance presets that match the specified comment.
[-privilege <PrivilegeLevel>]
- Preset Privilege Level (privilege: advanced)-
Selects the performance presets that are available with the specified privilege.
[-is-read-only {true|false}]
- Is Preset Read-Only? (privilege: advanced)-
Selects the performance presets that are read-only (true) or are not read-only (false). Read-only presets cannot be modified.
[-store <text>]
- Name of Store Where Data is Saved (privilege: advanced)-
Selects the store where data is saved.
cluster1::*> statistics preset show Preset Name Privilege Read-Only Comment ------------------- ---------- --------- -------------------------------------- aggregate_overview admin true This preset configuration is used by statistics aggregate show command. Provides overview of aggregate object. disk_overview advanced true This preset configuration is used by statistics disk show command. Provides overview of disk object. fcp_port_overview admin true This preset configuration is used by statistics port fcp show command. Provides overview of fcp port object. flash_pool_overview admin true This preset configuration is used by statistics cache flash-pool show command. Provides overview of flash pool object. [...]
