statistics preset show
Display information about Performance Presets
Displays information about performance preset configurations.
{ [-fields <fieldname>,…​]
Selects which performance preset attributes to display.
| [-instance ] }
Shows details of all attributes of performance preset configuration.
[-preset <text>] - Preset Name
Selects the performance presets that match the specified preset name.
[-comment <text>] - Preset Description
Selects the performance presets that match the specified comment.
[-privilege <PrivilegeLevel>] - Preset Privilege Level
Selects the performance presets that are available with the specified privilege.
[-is-read-only {true|false}] - Is Preset Read-Only?
Selects the performance presets that are read-only (true) or are not read-only (false). Read-only presets cannot be modified.
[-store <text>] - Name of Store Where Data is Saved
Selects the store where data is saved.
cluster1::*> statistics preset show
Preset Name         Privilege  Read-Only Comment
aggregate_overview  admin      true      This preset configuration is used by
                                         statistics aggregate show command.
                                         Provides overview of aggregate object.
disk_overview       advanced   true      This preset configuration is used by
                                         statistics disk show command.
                                         Provides overview of disk object.
fcp_port_overview   admin      true      This preset configuration is used by
                                         statistics port fcp show command.
                                         Provides overview of fcp port object.
flash_pool_overview admin      true      This preset configuration is used by
                                         statistics cache flash-pool show
                                         command. Provides overview of flash
                                         pool object.
