system node autosupport destinations show
Display a summary of the current AutoSupport destinations
The system node autosupport destinations show
command displays a list of all message destinations used by AutoSupport. The command provides you with a quick summary of all addresses and URLs that receive AutoSupport messages from all nodes in the cluster.
[-fields <fieldname>,…]
If you specify the
-fields <fieldname>, …
parameter, the command output also includes the specified field or fields. You can use '-fields ?' to display the fields to specify. - |
[-instance ]
If you specify the
-instance
parameter, the command displays detailed information about all fields. [-node {<nodename>|local}]
- Node-
Use this parameter to display only destinations that receive AutoSupport messages from the node you specify.
[-destinations <text>,…]
- Destinations-
Use this parameter to display only destination lists for nodes that send AutoSupport messages to the destinations you specify.
This example displays all of the destinations in use by the current cluster. Each node uses the same destination for HTTP POST, HTTP PUT, and e-mail notifications.
cluster1::> system node autosupport destinations show Node Destinations ------------------------------------------------------------------------------ node1 https://asuppost.example.com/cgi-bin/asup.cgi https://asupput.example.com/cgi-bin/asup.cgi support@example.com node2 https://asuppost.example.com/cgi-bin/asup.cgi https://asupput.example.com/cgi-bin/asup.cgi support@example.com
