Command reference
system node autosupport destinations show
Display a summary of the current AutoSupport destinations
The system node autosupport destinations show command displays a list of all message destinations used by AutoSupport. The command provides you with a quick summary of all addresses and URLs that receive AutoSupport messages from all nodes in the cluster.
{ [-fields <fieldname>,…​]
| [-instance ] }
[-node {<nodename>|local}] - Node
Use this parameter to display only destinations that receive AutoSupport messages from the node you specify.
[-destinations <text>,…​] - Destinations
Use this parameter to display only destination lists for nodes that send AutoSupport messages to the destinations you specify.
This example displays all of the destinations in use by the current cluster. Each node uses the same destination for HTTPS POST, HTTPS PUT, and e-mail notifications.
cluster1::> system node autosupport destinations show
Node
     Destinations
node1
     https://asuppost.example.com/cgi-bin/asup.cgi
     https://asupput.example.com/cgi-bin/asup.cgi
     support@example.com
node2
     support@example.com
