The requested article is not available. Either it doesn't apply to this version of the product or the relevant information is organized differently in this version of the docs. You can search, browse, or go back to the other version.
network subnet remove-ranges
PDF of this doc site
Creating your file...
Your file is ready
Remove address ranges from a subnet
Remove address ranges from a subnet.
-ipspace <IPspace>
- IPspace Name-
The IPspace in which the range resides.
-subnet-name <subnet name>
- Subnet Name-
The name of the subnet.
-ip-ranges {<ipaddr>|<ipaddr>-<ipaddr>}
- IP Ranges-
IP ranges to remove.
[-force-update-lif-associations <true>]
- Force Update LIF Associations-
This command will fail if any existing service processor interfaces or network interfaces are using IP addresses in the ranges provided. Using this parameter will remove the subnet's association with those interfaces and allow the command to succeed.
The following example removes an address range with starting address of 10.98.1.1
from subnet s1
in IPspace Default
cluster1::> network subnet remove-ranges -ipspace Default -subnet-name s1 -ip-ranges "10.98.1.1-10.98.1.30"
