network subnet remove-ranges
Remove address ranges from a subnet
Remove address ranges from a subnet.
-ipspace <IPspace>
- IPspace Name-
The IPspace in which the range resides.
-subnet-name <subnet name>
- Subnet Name-
The name of the subnet.
-ip-ranges {<ipaddr>|<ipaddr>-<ipaddr>}
- IP Ranges-
IP ranges to remove.
[-force-update-lif-associations <true>]
- Force Update LIF Associations-
This command will fail if any existing service processor interfaces or network interfaces are using IP addresses in the ranges provided. Using this parameter will remove the subnet's association with those interfaces and allow the command to succeed.
The following example removes an address range with starting address of 10.98.1.1
from subnet s1
in IPspace Default
cluster1::> network subnet remove-ranges -ipspace Default -subnet-name s1 -ip-ranges "10.98.1.1-10.98.1.30"
