volume quota policy delete
Delete a quota policy
This command deletes a quota policy and all the rules it contains. The policy can be deleted only when it is not assigned to the Vserver.You must enter the following information to delete a quota policy:
  • Vserver name
  • Policy name
-vserver <vserver name> - Vserver
This parameter specifies the Vserver containing the quota policy you want to delete.
-policy-name <text> - Policy Name
This parameter specifies the name of the quota policy you want to delete.
The following example deletes a quota policy named quota_policy_5 on Vserver vs0.
cluster1::> volume quota policy delete -vserver vs0 -policy-name quota_policy_5
