volume flexcache origin config show
Show FlexCache Origin Configuration
The volume flexcache origin config show
command displays volume specific options of an origin of a FlexCache volume.
[-fields <fieldname>,…]
If you specify the
-fields <fieldname>, …
parameter, the command output also includes the specified field or fields. You can use '-fields ?' to display the fields to specify. - |
[-instance ]
If you specify the
-instance
parameter, the command displays detailed information about all fields. [-origin-vserver <Vserver Name>]
- Vserver Name-
If this parameter and the
-origin-volume
parameter are specified, the command displays options for the specified origin of a FlexCache volume. If this parameter is specified by itself, the command displays options for all origin of a FlexCache volumes in the specified Vserver. [-origin-volume <volume name>]
- Origin Volume Name-
If this parameter is specified, the command displays options for the specified origin of a FlexCache volume.
[-is-bli-enabled {true|false}]
- Is BLI Enabled-
If this parameter is specified, the command displays the origin of a FlexCache volume matching the specified value. Possible values are:
false
- Block level invalidation is not set -
true
- Block level invalidation is set
[-is-global-file-locking-enabled {true|false}]
- Is Global File Locking Enabled-
If this parameter is specified, the command displays the origin configurations matching the specified value. Global file locking mode is a mode where protocol read locking semantics are enforced across all FlexCaches and origins of a FlexCache volume. To completely disable/enable global file locking mode, kindly use "flexcache origin config modify" command in advanced privilege with
set totrue
/false
depending upon the requirement. When global file locking mode is enabled for the volume, the "is_disconnected_mode_off_for_locks" flag is always set totrue
. Possible values are:-
false
- Global file locking mode is not set -
true
- Global file locking mode is set
The following example displays FlexCache origin options:
cluster1::> volume flexcache origin config show (volume flexcache origin config show) Origin-Vserver Origin-Volume Is-BLI-Enabled Is-Global-File-Locking- Enabled --------------- --------------- -------------- ------------------------------ vs34 origin1 true true vs34 origin2_new false false 2 entries were displayed.
