volume flexcache origin config show
Show FlexCache Origin Configuration
The volume flexcache origin config show command displays volume specific options of an origin of a FlexCache volume.
- { [-fields <fieldname>,…]
If you specify the -fields <fieldname>, …parameter, the command output also includes the specified field or fields. You can use '-fields ?' to display the fields to specify.
- | [-instance ]}
If you specify the -instanceparameter, the command displays detailed information about all fields.
- [-origin-vserver <Vserver Name>]- Vserver Name (privilege: advanced)
If this parameter and the -origin-volumeparameter are specified, the command displays options for the specified origin of a FlexCache volume. If this parameter is specified by itself, the command displays options for all origin of a FlexCache volumes in the specified Vserver.
- [-origin-volume <volume name>]- Origin Volume Name (privilege: advanced)
If this parameter is specified, the command displays options for the specified origin of a FlexCache volume.
- [-is-bli-enabled {true|false}]- Is BLI Enabled (privilege: advanced)
If this parameter is specified, the command displays the origin of a FlexCache volume matching the specified value. Possible values are: -
false- Block level invalidation is not set
true- Block level invalidation is set
- [-is-global-file-locking-enabled {true|false}]- Is Global File Locking Enabled (privilege: advanced)
If this parameter is specified, the command displays the origin configurations matching the specified value. Global file locking mode is a mode where protocol read locking semantics are enforced across all FlexCaches and origins of a FlexCache volume. To completely disable/enable global file locking mode, kindly use "flexcache origin config modify" command in advanced privilege with -is-global-file-locking-enabledset totrue/falsedepending upon the requirement. When global file locking mode is enabled for the volume, the "is_disconnected_mode_off_for_locks" flag is always set totrue. Possible values are:-
false- Global file locking mode is not set
true- Global file locking mode is set
The following example displays FlexCache origin options:
cluster1::> volume flexcache origin config show
  (volume flexcache origin config show)
Origin-Vserver   Origin-Volume    Is-BLI-Enabled  Is-Global-File-Locking-
                                                  Enabled
vs34             origin1          true            true
vs34             origin2_new      false           false
2 entries were displayed.
 PDFs
PDFs
