volume flexcache origin config show
Show FlexCache Origin Configuration
The volume flexcache origin config show command displays volume specific options of an origin of a FlexCache volume.
[-fields <fieldname>,…] -
If you specify the
[-instance ]} -
If you specify the
-instanceparameter, the command displays detailed information about all fields. [-origin-vserver <Vserver Name>]- Vserver Name (privilege: advanced)-
If this parameter and the
-origin-volumeparameter are specified, the command displays options for the specified origin of a FlexCache volume. If this parameter is specified by itself, the command displays options for all origin of a FlexCache volumes in the specified Vserver. [-origin-volume <volume name>]- Origin Volume Name (privilege: advanced)-
If this parameter is specified, the command displays options for the specified origin of a FlexCache volume.
[-is-bli-enabled {true|false}]- Is BLI Enabled (privilege: advanced)-
If this parameter is specified, the command displays the origin of a FlexCache volume matching the specified value. Possible values are:
false- Block level invalidation is not set -
true- Block level invalidation is set
[-is-global-file-locking-enabled {true|false}]- Is Global File Locking Enabled (privilege: advanced)-
If this parameter is specified, the command displays the origin configurations matching the specified value. Global file locking mode is a mode where protocol read locking semantics are enforced across all FlexCaches and origins of a FlexCache volume. To completely disable/enable global file locking mode, kindly delete all the FlexCache relationship (s) and recreate FlexCache relationship (s) with global file locking mode set to true/false depending upon the requirement. Possible values are:
false- Global file locking mode is not set -
true- Global file locking mode is set
The following example displays FlexCache origin options:
cluster1::> volume flexcache origin config show
(volume flexcache origin config show)
Origin-Vserver Origin-Volume Is-BLI-Enabled Is-Global-File-Locking-
Enabled
vs34 origin1 true true
vs34 origin2_new false false
2 entries were displayed.
