volume flexcache origin config show
PDF of this doc site
Creating your file...
Show FlexCache Origin Configuration
The volume flexcache origin config show
command displays volume specific options of an origin of a FlexCache volume.
[-fields <fieldname>,…]
If you specify the
-fields <fieldname>, …
parameter, the command output also includes the specified field or fields. You can use '-fields ?' to display the fields to specify. - |
[-instance ]
If you specify the
-instance
parameter, the command displays detailed information about all fields. [-origin-vserver <Vserver Name>]
- Vserver Name (privilege: advanced)-
If this parameter and the
-origin-volume
parameter are specified, the command displays options for the specified origin of a FlexCache volume. If this parameter is specified by itself, the command displays options for all origin of a FlexCache volumes in the specified Vserver. [-origin-volume <volume name>]
- Origin Volume Name (privilege: advanced)-
If this parameter is specified, the command displays options for the specified origin of a FlexCache volume.
[-is-bli-enabled {true|false}]
- Is BLI Enabled (privilege: advanced)-
If this parameter is specified, the command displays the origin of a FlexCache volume matching the specified value. Possible values are:
false
- Block level invalidation is not set -
true
- Block level invalidation is set
[-is-global-file-locking-enabled {true|false}]
- Is Global File Locking Enabled (privilege: advanced)-
If this parameter is specified, the command displays the origin configurations matching the specified value. Global file locking mode is a mode where protocol read locking semantics are enforced across all FlexCaches and origins of a FlexCache volume. To completely disable/enable global file locking mode, kindly use "flexcache origin config modify" command in advanced privilege with
set totrue
/false
depending upon the requirement. When global file locking mode is enabled for the volume, the "is_disconnected_mode_off_for_locks" flag is always set totrue
. Possible values are:-
false
- Global file locking mode is not set -
true
- Global file locking mode is set
The following example displays FlexCache origin options:
cluster1::> volume flexcache origin config show (volume flexcache origin config show) Origin-Vserver Origin-Volume Is-BLI-Enabled Is-Global-File-Locking- Enabled --------------- --------------- -------------- ------------------------------ vs34 origin1 true true vs34 origin2_new false false 2 entries were displayed.
