Command reference
volume flexcache origin config show
Show FlexCache Origin Configuration
The volume flexcache origin config show command displays volume specific options of an origin of a FlexCache volume.
[-fields <fieldname>,…​]
| [-instance ] (privilege: advanced) }
[-origin-vserver <Vserver Name>] - Vserver Name (privilege: advanced)
If this parameter and the -origin-volume parameter are specified, the command displays options for the specified origin of a FlexCache volume. If this parameter is specified by itself, the command displays options for all origin of a FlexCache volumes in the specified Vserver.
[-origin-volume <volume name>] - Origin Volume Name (privilege: advanced)
If this parameter is specified, the command displays options for the specified origin of a FlexCache volume.
[-is-bli-enabled {true|false}] - Is BLI Enabled (privilege: advanced)
If this parameter is specified, the command displays the origin of a FlexCache volume matching the specified value. Possible values are:
  • false - Block level invalidation is not set
  • true - Block level invalidation is set
[-is-global-file-locking-enabled {true|false}] - Is Global File Locking Enabled (privilege: advanced)
If this parameter is specified, the command displays the origin configurations matching the specified value. Global file locking mode is a mode where protocol read locking semantics are enforced across all FlexCache volumes and origins of a FlexCache volume. To completely disable/enable global file locking mode, use flexcache origin config modify in advanced privilege with -is-global-file-locking-enabled set to true /false depending upon the requirement. When global file locking mode is enabled for the volume, the "is_disconnected_mode_off_for_locks" flag is always set to true . Possible values are:
  • false - Global file locking mode is not set
  • true - Global file locking mode is set
The following example displays FlexCache origin options:
cluster1::> volume flexcache origin config show
  (volume flexcache origin config show)
Origin-Vserver   Origin-Volume    Is-BLI-Enabled  Is-Global-File-Locking-
                                                  Enabled
vs34             origin1          true            true
vs34             origin2_new      false           false
2 entries were displayed.
