volume rebalance file-move modify
Modify a file-move operation
The volume rebalance file-move modify
command modifies certain attributes of a file-move operation that is currently in progress. Specifically, the maximum throughput allowed on a particular file-move operation can be modified, and the data transfer of a file-move operation can be paused or resumed.
command is only supported on FlexGroup volumes. For a given FlexGroup volume, there can be many file-move operations that are currently in progress for different sets of constituents. The parameters for this command provide a way to identify a particular file-move operation within a FlexGroup volume.
-vserver <vserver name>
- Vserver Name-
Identifies the Vserver that contains the FlexGroup volume involved in the file-move operation.
-volume <volume name>
- Volume Name-
Identifies the FlexGroup volume that is hosting the file being moved in the file-move operation.
-path <text>
- Path-
Identifies the path to the file being moved within the FlexGroup volume. This parameter can be specified with the
-destination-constituent
parameter to identify a particular file-move operation within a FlexGroup volume. -destination-constituent <volume name>
- Destination Constituent Volume-
Identifies the destination constituent name of the FlexGroup volume where the file is being moved. This parameter can be specified with the
-path
parameter to identify a particular file-move operation within a FlexGroup volume. [-operation-uuid <UUID>]
- Operation UUID-
Identifies the UUID of the file-move operation. Use the volume rebalance file-move show command to obtain the UUID for a file-move operation. This parameter can be specified in addition to the
-path
and-destination-constituent
parameters to identify a particular file-move operation if there are multiple ongoing operations involving the same path and destination constituent. [-max-throughput {<integer>[KB|MB|GB|TB|PB]}]
- Maximum Scanner Speed-
If specified, this parameter will modify the rate limit for the data transfer in bytes per second. A non-zero value less than 1 MB/s will be set to 1 MB/s. A non-zero value greater than 1 MB/s will be truncated to the nearest integral megabyte value. A value of "0" specifies that no range will be set for the data transfer. This value does not represent a throughput the system will guarantee, but a limit that cannot be exceeded.
[-scanner-paused {true|false}]
- Scanner Paused-
If specified, the data transfer of the file-move operation will be paused or resumed. Using a value of
false
will pause the data transfer while using a value oftrue
will resume the data transfer.
The following example modifies the maximum throughput of the ongoing file-move operation for the file "/system/build/image.tgz" within the FlexGroup volume "bld_volume". -path
and -destination-constituent
are used to identify the particular file-move operation:
cluster1::*> volume rebalance file-move modify -vserver vs0 -volume bld_volume -path /system/build/image.tgz -destination-constituent bld_volume__0005 -max-throughput 2MB
The following example pauses the data transfer of the ongoing file-move operation for the file "/system/build/image.tgz" within the FlexGroup volume "bld_volume". This stops any further data from being transferred from the source volume to the destination volume:
cluster1::*> volume rebalance file-move modify -vserver vs0 -volume bld_volume -path /system/build/image.tgz -destination-constituent bld_volume__0005 -scanner-paused true
The following example resumes the data transfer of a paused file-move operation for the file "/system/build/image.tgz" within the FlexGroup volume "bld_volume". -path
cluster1::*> volume rebalance file-move modify -vserver vs0 -volume bld_volume -path /system/build/image.tgz -destination-constituent bld_volume__0005 -scanner-paused false
