vserver object-store-server group delete
Delete an Object Store Server Group
The vserver object-store-server group delete
command deletes an object store group.
-vserver <Vserver Name>
- Vserver Name-
This parameter specifies the name of the Vserver for the object store server you want to delete.
-gid <integer>
- Group ID-
This parameter specifies the ID of the object store group you want to delete.
The following example deletes an object store group for Vserver vs1:
cluster1::> vserver object-store-server group delete -vserver vs1 -gid 1
