ONTAP commands
vserver cifs prepare-to-downgrade
Restore the CIFS Configurations to Earlier Release of Data ONTAP Version
The vserver cifs prepare-to-downgrade command restores the CIFS configurations for Data ONTAP based on the input parameter disable-feature-set.
-disable-feature-set <downgrade version> - Data ONTAP Version (privilege: advanced)
This parameter specifies the Data ONTAP release for which the CIFS configurations are restored. The value can be one of the following:
  • 8.3.1 - Restores the CIFS configurations for Data ONTAP release 8.3.1. These features include:
  • FPolicy "close with read" filters from FPolicy events.
  • CIFS server options -guest-unix-user and -is-admin-users-mapped-to-root-enabled .
  • CIFS security option is-smb-encryption-required .
  • Storage-Level Access Guard (SLAG) for qtrees.
  • CIFS share property encrypt-data.
  • 8.3.2 - Restores the CIFS configurations for Data ONTAP release 8.3.2. These features include:
  • CIFS server option -grant-unix-group-perms-to-others .
  • 9.0.0 - Restores the CIFS configurations for Data ONTAP release 9.0.0. These features include:
  • Disable CIFS multichannel feature and close all multichannel connections.
  • Delete all the name-mapping entries that have a hostname or an address field configured.
  • Terminate all SMB 3.1 client connections.
  • Terminate all client connections that have large MTU negotiated.
  • Remove the symlink property no-strict-security .
  • Remove all symlink pathmap entries with locality freelink .
cluster1::*> vserver cifs prepare-to-downgrade -disable-feature-set 8.3.1
cluster1::*> vserver cifs prepare-to-downgrade -disable-feature-set 8.3.2
cluster1::*> vserver cifs prepare-to-downgrade -disable-feature-set 9.0.0
