event filter rule reorder
Modify the index of a rule for an event filter
The event filter rule reorder command moves a rule to a new position in an existing event filter. Use event filter show command to display all the event filters and the rules associated with them.
-filter-name <text> - Filter Name
Use this mandatory parameter to specify the name of the event filter from which you want to change the position of the rule. Rules from system-defined event filters cannot be modified.
-position <integer> - Rule Positon
Use this mandatory parameter to specify the position of the rule you want to change. It should be in the range (1..n-1), where 'n' is the position of the last rule, which is an implicit rule.
-to-position <integer> - New Rule Position
Use this mandatory parameter to specify the new position to move the rule. It should be in the range (1..n-1), where 'n' is the position of the last rule, which is an implicit rule.
The following example changes the position of a rule from 1 to 2 from an existing event filter "emer-and-wafl":
cluster1::> event filter show
Filter Name Rule     Rule      Message Name           SNMP Trap Type  Severity
            Position Type
default-trap-events
            1        include   *                      *               EMERGENCY, ALERT
            2        include   *                      Standard, Built-in
            3        exclude   *                      *               *
emer-and-wafl
            1        include   wafl.scan.*            *               ALERT
            2        include   *                      Standard        *
            3        exclude   *                      *               *
important-events
            2        include   callhome.*             *               ERROR
            3        exclude   *                      *               *
no-info-debug-events
            1        include   *                      *               EMERGENCY, ALERT, ERROR, NOTICE
            2        exclude   *                      *               *
11 entries were displayed.
cluster1::> event filter rule reorder -filter-name emer-and-wafl -position 1 -to-position 2
            Position Type
default-trap-events
            3        exclude   *                      *               *
emer-and-wafl
            1        include   *                      Standard        *
            2        include   wafl.scan.*            *               ALERT
            3        exclude   *                      *               *
important-events
            3        exclude   *                      *               *
            2        exclude   *                      *               *
