vserver iscsi initiator show
Display iSCSI initiators currently connected
This command displays a list of active initiators currently connected to a specified Vserver.
[-fields <fieldname>,…]
If you specify the
-fields <fieldname>, …
parameter, the command output also includes the specified field or fields. You can use '-fields ?' to display the fields to specify. - |
[-instance ]
If you specify the
-instance
parameter, the command displays detailed information about all fields. [-vserver <Vserver Name>]
- Vserver-
Use this parameter to display the active initiators that match the Vserver that you specify.
[-tpgroup <text>]
- Target Portal Group-
Use this parameter to display the active initiators that match the name of the target portal group that you specify.
[-tsih <integer>]
- Target Session ID-
Use this parameter to display the active initiators that match the target session ID you that specify.
[-initiator-name <text>]
- Initiator Name-
Use this parameter to display the active initiators that match the initiator name that you specify.
[-initiator-alias <text>]
- Initiator Alias-
Use this parameter to display the active initiators that match the alias name that you specify.
[-tpgroup-tag <integer>]
- TPGroup Tag-
Use this parameter to display the active initiators that match the target portal group tag that you specify.
[-isid <text>]
- Initiator Session ID-
Use this parameter to display the active initiators that match the initiator session ID that you specify.
[-igroup <text>,…]
- Igroup Name-
Use this parameter to display the active initiators that match the initiator group that you specify.
cluster1::> vserver iscsi initiator show -vserver vs_1 Tpgroup Initiator Vserver Name TSIH Name ISID IGroup ------- -------- ---- --------------------- ----------------- ----------------- vs_1 vs_1.iscsi 6 iqn.1994-05.com.redhat:6ed6dfb0489e 00:02:3d:03:00:00 - vs_1 vs_1.iscsi 7 iqn.1993-08.org.debian:01:fa752b8a5a3a 00:02:3d:01:00:00 igroup_1 2 entries were displayed.
Displays the active initiator information on Vserver vs_1.
