vserver iscsi initiator show
Display iSCSI initiators currently connected
This command displays a list of active initiators currently connected to a specified Vserver.
[-fields <fieldname>,…] -
If you specify the
[-instance ]} -
If you specify the
-instanceparameter, the command displays detailed information about all fields. [-vserver <Vserver Name>]- Vserver-
Use this parameter to display the active initiators that match the Vserver that you specify.
[-tpgroup <text>]- Target Portal Group-
Use this parameter to display the active initiators that match the name of the target portal group that you specify.
[-tsih <integer>]- Target Session ID-
Use this parameter to display the active initiators that match the target session ID you that specify.
[-initiator-name <text>]- Initiator Name-
Use this parameter to display the active initiators that match the initiator name that you specify.
[-initiator-alias <text>]- Initiator Alias-
Use this parameter to display the active initiators that match the alias name that you specify.
[-tpgroup-tag <integer>]- TPGroup Tag-
Use this parameter to display the active initiators that match the target portal group tag that you specify.
[-isid <text>]- Initiator Session ID-
Use this parameter to display the active initiators that match the initiator session ID that you specify.
[-igroup <text>,…]- Igroup Name-
Use this parameter to display the active initiators that match the initiator group that you specify.
cluster1::> vserver iscsi initiator show -vserver vs_1
Tpgroup Initiator
Vserver Name TSIH Name ISID IGroup
vs_1 vs_1.iscsi 6 iqn.1994-05.com.redhat:6ed6dfb0489e
00:02:3d:03:00:00 -
vs_1 vs_1.iscsi 7 iqn.1993-08.org.debian:01:fa752b8a5a3a
00:02:3d:01:00:00 igroup_1
2 entries were displayed.
Displays the active initiator information on Vserver vs_1.
